Hi Shankar,
Thanks a lot for your reply. I want to extract spice netlist with Star-RC and Hercules for analog circuit. The input is the prelayout hspice netlist. I want to run post-layout simulation with the paratisics. Could you tell how to do it?
* Netlisting
netlist_comments_file:run_details/compare/sum.top_digital
netlist_connect_opens:!*
netlist_file:top_digital.star
netlist_format:star
netlist_name_map:yes
netlist_ideal_spice_file: xlpe.sp
* NETLIST_IDEAL_SPICE_TYPE: LAYOUTi to ouput netlist which reference to LAYOUT DB and SCHEM which reference to SCHEMATIC
* HN_NETLIST_SPICE_TYPE: MN MP X
*HIERARCHICAL_SEPARATOR: <| | / |.|:>
HIERARCHICAL_SEPARATOR:.
* Noise Analysis
coupling_abs_threshold:1e-16
coupling_rel_threshold:0.1
coupling_report_file:coupling_report.txt
coupling_report_number:1000
* Processing
* nets: fpll200M I154/n271 SHAREI - This option is used to extract a list of specify NETS
power_extract:no
remove_floating_nets:yes
short_pins:yes
skip_cells:*
