spi communication commands problem in data logging applications.
veerubiji
Full Member level 2
This is veera reddy, i have a problem with spi commands in my application, i am trying to log sensor data from sensor tag. here sensor ic chip is mlx90129 it is located on the evb90129 board. this chip having internal eeprom there is noproblem when reading internal memory. this evalution board having external eeprom to store more data, for that i am using spi communication to log the data from external memory. can any one suggest me which comands is useful for that data logging from external memory. data sheet available at MLX90129.
  • MLX90129_Datasheet_March_2010.pdf
  • AN2_MLX90129_Data_Logging.pdf
  • EVB90129.pdf
There's no need to crosspost. Check your other postings and you will find your answers.
