HI
PLEASE HELP ME
I am an engineering student trying to learn SPI communication using pic16f877a and mikroc compiler.I wrote 2 codes one for pic spi master that continuously sends digit 3 and another code for pic spi slave that listens to master and makes the RB0 pin high if digit 3 is received.When i simulated it on proteus7.1 i could see the state change of SCK pin and SD0 pin of spimaster but nothing happend at the slave side. i am giving my codes below,please point out the bug or give me some sample code for both master and slave in mikroc.please help me
project settings
for both master and slave)
mikroc v 6.2.1.0
microcontroller:16f877a
configuration settings default
clock frequency 12mhz
// code for spi master
void main()
Spi_Init_Advanced(MASTER_OSC_DIV64,DATA_SAMPLE_MIDDLE,CLK_IDLE_LOW,HIGH_2_LOW);
while(1)
Spi_Write(3);
// code for spi slave
void main()
unsigned char buffer,gdata=0x00;
buffer=0x00;
TRISB=0X00;
portb=0x00;
Spi_Init_Advanced(SLAVE_SS_ENABLE,DATA_SAMPLE_MIDDLE,CLK_IDLE_LOW,HIGH_2_LOW);
while(1)
gdata=Spi_Read(buffer);
if(gdata==3)
portb.f0=1;
