tajiknomi
Member level 4
I am trying to connect my PIC to RTC. The RTC I am using is DS1302 with only one pin for both (Input and Output). I am trying to simulate it using PROTEUS. The problem I am facing is how can I connect PIC two pins i.e. SDO and SDI to one pin (I/O) of RTC?
ScreenShot is here
If i make SDO or SDI pin somehow "IN-ACTIVE" for a time then maybe i can succesffuly comunicate b/w PIC and RTC. By the term "In-Active" i means that i make let say SDO pin disable (while recieving byte) i.e. making SDO Neither Input Nor Output for a certain time. How can i achieve this goal.
I have read the datasheet of 16fxxxx but couldn't find the configuration for 3 wire communication.
Any help would be appreciated.
Thank you
ScreenShot is here
Thank you
