[SOLVED] Speed of a moving table.
USMCinfinity
Member level 1
Puerto Rico
Hey guys, do any of you know any method or device that I can use to measure the speed of a moving table (circle)?
This is a very important aspect of calibration for a ADS calibration.
Regards,
Miguel A. Cruz
use a magnet and hall sensor. fix the magnet to the table and hall sensor to your measuring circuit.
That's the problem, I have no idea what a measuring circuit for this be like?
---------- Post added at 16:38 ---------- Previous post was at 15:47 ----------
Would there be a way to convert the output current to speed?
Rather than measure the output current, count the number of times the sensor is activated in a given period of time. Since one revolution is equal to a fixed distance (circumference!), you have distance and time, thus velocity or speed. A µP could handle all of this...
Ok, so lets say the table has a diameter of 1 ft, and the sensor activated 20 times in 1 minute, hence 20 RPM. What would the speed of it be? Also what is a uP?
mph = (rpm * cir) / (gear * final * 88)
where rpm = engine rpm
cir = tire cicumference, in feet
gear = gear ratio of your car
final = final drive ratio of your car
88 = combines several conversion factors
I found this online, can I apply this formula for my situation? Eliminating the division part?
