ttse7
Junior Member level 2
Hi all,
First of all, my problem is about using spectrum analyzer for measuring uwb signal and I am not sure whether it is a right place for my question. If not, please notify me.
I use a handheld spectrum analyzer to measure a antenna output of a uwb transceiver. In fact, this is RTU7010 which comes from Realtek. I configure this uwb transceiver to transmit signal and connect the antenna output to spectrum analyzer using a rf coaxial cable but nothing is detected. The datas is 53Mbps in rate, OFDM modulated and time-frequency-interleafed. Is there particular setting needed to be done in order to measure this such high bandwidth signal.
My handheld spectrum analyzer is FSH6. I can use this analyzer to measure IEEE802.11g signal successfully.
Thanks for your attention.
ttse7
ttse7
