spectre netlist generation error
ezbentley
Junior Member level 3
I am having problem with the netlist generated by spectre. In the Virtuoso schematic editor, I have a simple nmos with model name "nmos_rfw5" but the netlist shows:
NM0 (net5 net3 0 0) subcircuit
However, the correct netlist should be:
NM0 (net5 net3 0 0) nmos_rfw5
This error is preventing me from doing any work. Any help will be greatly appreciated. Thanks.
safwatonline
EGYPT
did u add the model name in the instance.
ezbentley
I did add the model name in the instance. In the property window in the schematic, the "model name" field shows "nmos_rfw5"
pit1000
If you use the design kit, the transistor can be realized as subcircuitt. Look model file and CDF .
pfd001
Advanced Member level 1
u can use a transitor symbol from analogLib.
hqqh
Full Member level 4
it seems that you have specified the correct model lib, because spectre doen't give the error "unknown simulation model". But how is the transistor model defined? Is it a subcircuit, a inline subcircuit or a standard bsim model?
An other point is, as I know, the environmen variable CDS_Netlisting_Node has to be set to the value Analog.
Greetings,
hqqh
