Hi everyone!
I just installed Cadence Virtuoso and MMSIM under Linux Mint 18.1 64 bit. I have performed the installation following the instructions of the thread "Cadence Virtuoso and MMSIM installation". I want to specify that it's my second installation, first one performed in 64 bit.
Everything worked as expected. I setted up the .bashrc in the same way I did with the 32 bit of Linux Mint, and Virtuoso started without problem.
So I decided to simulate a circuit and I got some problems. The first one was an error ADE-3036 that I managed to resolve with the following:
1) install libreadline5
2) go to ADE-->Setup-->Environment Options, thick "Run With 64 bit binary" option
Now when I simulate a circuit I get this error in the output log:
Notice from spectre during license check-out.
Waiting for available license for Virtuoso(R) Spectre.
And the simulation doesn't proceed.
I also went to see the output of the runSimulation file in the netlist directory to know the exact cause of the error, and this is the result:
WARNING: HOST <hostname> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
For More Info, Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
When I run checkSysConf I only get this:
theHost: Undefined variable.
At this point I don't know anymore what to do. Can anyone please help me?
