Spartan 6 x Spartan 7 Logic use comparison
pbernardi
Full Member level 3
Hello All,
I was going to use an Spartan-7 device on my new project, but some colleagues were arguing to keep with current Spartan-6 due code compatibility reasons.
So, I my first idea was to make a synthesis of some codes we have for comparison, and I am reaching the conclusion that the Spartan-7 (and family 7 in general) is less efficient from logic point of view than Spartan-6? It seems odd to me.
Conditions and comments:
- I will not use any unique feature from 7 series family (ADC for example)
- Power and maximum speed are not so relevant here, only logic use.
- Of course, the code I use was developed for Spartan-6, so it might happen that they are optimized for 6-family, but still.
- They have different environment (ISE 14.7 x Vivado 2017.3)
- Seems that Artix-7/Spartan-7 have similar behavior regarding logic usage.
- There are differences specially related to the Block RAM size, I'm aware of that.
For example, a reference project (did not fix the I/O pins, balanced optimization in both cases):
For Spartan 6, using XC6SLX75-2CSG484:
Device Utilization Summary:
Slice Logic Utilization:
  Number of Slice Registers:                   980 out of  93,296    1%
    Number used as Flip Flops:                 980
    Number used as Latches:                      0
    Number used as Latch-thrus:                  0
    Number used as AND/OR logics:                0
  Number of Slice LUTs:                      4,404 out of  46,648    9%
    Number used as logic:                    4,051 out of  46,648    8%
      Number using O6 output only:           3,097
      Number using O5 output only:             206
      Number using O5 and O6:                  748
      Number used as ROM:                        0
    Number used as Memory:                     335 out of  11,072    3%
      Number used as Dual Port RAM:            268
        Number using O6 output only:           108
        Number using O5 output only:            16
        Number using O5 and O6:                144
      Number used as Single Port RAM:           65
        Number using O5 output only:             0
        Number using O5 and O6:                 64
      Number used as Shift Register:             2
        Number using O6 output only:             2
        Number using O5 and O6:                  0
    Number used exclusively as route-thrus:     18
      Number with same-slice register load:      1
      Number with same-slice carry load:        17
      Number with other load:                    0
Slice Logic Distribution:
  Number of occupied Slices:                 1,597 out of  11,662   13%
  Number of MUXCYs used:                       560 out of  23,324    2%
  Number of LUT Flip Flop pairs used:        4,554
    Number with an unused Flip Flop:         3,703 out of   4,554   81%
    Number with an unused LUT:                 150 out of   4,554    3%
    Number of fully used LUT-FF pairs:         701 out of   4,554   15%
    Number of slice register sites lost
      to control set restrictions:               0
For Artix-7, using a XC7A75tcsg324-2:
1. Slice Logic
|          Site Type         | Used | Fixed | Available | Util% |
| Slice LUTs                 | 5402 |     0 |     47200 | 11.44 |
|   LUT as Logic             | 5178 |     0 |     47200 | 10.97 |
|   LUT as Memory            |  224 |     0 |     19000 |  1.18 |
|     LUT as Distributed RAM |  224 |     0 |           |       |
|     LUT as Shift Register  |    0 |     0 |           |       |
| Slice Registers            | 3207 |     0 |     94400 |  3.40 |
|   Register as Flip Flop    | 3207 |     0 |     94400 |  3.40 |
|   Register as Latch        |    0 |     0 |     94400 |  0.00 |
| F7 Muxes                   |  961 |     0 |     31700 |  3.03 |
| F8 Muxes                   |  132 |     0 |     15850 |  0.83 |
2. Slice Logic Distribution
| Slice                                     | 2173 |     0 |     15850 | 13.71 |
|   SLICEL                                  | 1502 |     0 |           |       |
|   SLICEM                                  |  671 |     0 |           |       |
|   using O5 output only                    |    0 |       |           |       |
|   using O6 output only                    | 4686 |       |           |       |
|   using O5 and O6                         |  492 |       |           |       |
|     using O6 output only                  |  128 |       |           |       |
|     using O5 and O6                       |   96 |       |           |       |
| LUT Flip Flop Pairs                       |  575 |     0 |     47200 |  1.22 |
|   fully used LUT-FF pairs                 |  150 |       |           |       |
|   LUT-FF pairs with one unused LUT output |  416 |       |           |       |
|   LUT-FF pairs with one unused Flip Flop  |  417 |       |           |       |
| Unique Control Sets                       |  339 |       |           |       |
* Note: Review the Control Sets Report for more information regarding control sets.
3. Memory
| Block RAM Tile    |   13 |     0 |       105 | 12.38 |
|   RAMB36/FIFO*    |    8 |     0 |       105 |  7.62 |
|     RAMB36E1 only |    8 |       |           |       |
|   RAMB18          |   10 |     0 |       210 |  4.76 |
|     RAMB18E1 only |   10 |       |           |       |
* Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1
Both uses the same code, but Spartan/Artix-7 has a worse logic usage in general, specially when taking into account the LUT usage. Has anyone here made similar investigation?
For a start you're using two different synthesis tools. Therefore the output generated is going to be different.
You can probably use the netlist and just load that onto a 7 series.
For obsolescence alone you should probably go for a 7 series.
Yes, but I expected Series 7 to be better, not the opposite.
No way. Families 6 and 7 use different DSPs and BRAM, at least.
Series 6 is guaranteed for more 7-8 years at least, it is enough for me.
I think there is something wrong with your analysis as the number of FFs between the designs is 980 vs 3207. That is something that should not change much.
You are probably doing your analysis with an apples to pineapples set of synth/par settings.
May be, checking the FFs is a good hint. I had already found a divergence regarding a BRAM mapped as a distributed RAM, but maybe there are additional problems, I'll double check.
That FF explosion is really a case for BRAM not being mapped. Have you got some inferred ram in there that doesnt work in an Artix 7?
Yes, the way I described some double-access BRAMs was not well accepted by Vivado, despite being ok for ISE. Anyway, this was supposedly solved before I post the code in #1.
Is there a easy way to investigate what this "FF explosion" could be? I looked at utilization report and synthesis report but I didn't get any obvious hint.
check through the warnings about RAMs not being inferred and the like.
