tigertag
Newbie level 1
Hi
I am using Xilinx Ise 10.1 with Spartan-3e FPGAs. I have a strange problem. My program is reading data from a pin and then runs a finite state machine structure to determine the response. I made a test port, directed some signals to the test ports and connected a logic analyser to the test ports to debug the program. The program was running well. However when i deleted the test port the program is not running correct. When i add test pins to see the signals the program starts running correct again. By the way the test pins are not connected to anywhere else and are not used in any part of decision making algorithm. Could you please help me with the problem.
Hakkı KAPLAN
Udea Electronics
Hakkı KAPLAN
Udea Electronics
