spark generator..need help
Alwaleed2
Member level 3
need a circuit to generate a spark to use in a cooker
You mean for ignition on a gas grill?
Those that I have seen use a piezoelectric element, with no other electronic components.
Is this what you are trying to duplicate?
yes the one like the used in heater and gas grill , I search for an electronic alternate
Easiest might be to use a mains driven neon sign transformer.
More electronic techniques include:
https://www.repairfaq.org/sam/hvinvert.htm
Or, perhaps, a simple application using an automotive ignition coil.
You could probably get something to work based on a strobe light transformer.
