sound recorder using PIC
Ren_DBK
Newbie level 2
Newbie level 2
Singapore
pic sound recorder
Hi, I m trying to build a sound recording and playing back system using PIC 16F877.
I want to build a system that can record several pieces of sound and then PIC can choose any piece to play back.
I need filters amplifiers and memory, am i rite?
Is this doable?
Can anyone suggest ways to build this ?
sound recorder + pic
It is hard to do with normal 8 bit micros and i think pic 16f877 does not have speed to do this.
Try using some high speed devices
Nandhu
Reactions: ogr
    ogr
pic audio recorder
Yes, You can use pic 16f877 to control the chip
Happy programming
Nandhu
recording circuit using pic
Is this doable?
Hello,
Yes it's doable ... check this out :
https://www.romanblack.com/picsound.htm
Re: pic sound recorder
Is this doable?
you can use the apr9600 for recording voice & then pic16f877a for random access to the multi recorded voice signals.
hello,
Can we do the same using PIC24FJ128GA010 ? If yes which pins can we use ,,.... I mean to make a circuit for digital sound tracking using "digital voice recorder kit" ??
Thank you.
Regards.
Nikhil Raj.
