Some warnings during NanoRoute
Greatrebel
Member level 3
HiAll,
When I run Nanoroute with globalDetailRoute in Encounter, I got a few warnings like below
#WARNING (NRDB-733) PIN Y in CELL_VIEW top,init does not have physical port
#WARNING (NRDB-733) PIN acc_out[0] in CELL_VIEW top,init does not have physical port
These pins are chip pins on the top module. The rest of pins are fine. I think I treat these pins and other pins same in my code and script. So I have no idea about what these warnings mean.
Any help will be appreciated
Re: Some warnings during NanoRout
any help?
thanks
Hi Greatrebel,
The warning messages means if a top level pin is not logical, that is, it is placed, then it must have some geometries defined.
You may output the def file, the check the PIN Y for something like:
+ PIN Y
+ LAYER Mx (x1 y1) (x2 y2)
Hi xunuu,
I have found out the informatio about thoes pins in def file like below. Does it mean it is OK for having those warnings.
Thank you very much for your help.
( PIN Y ) ( amp1 Y ) ( IOAOUT_Y AIO )
+ ROUTED M2 ( 1411480 1579760 ) ( * 1690640 0 )
NEW M1 ( 1411480 1579760 ) ( 1417080 * )
NEW M1 ( 1417080 1579510 ) ( 1462440 * 0 )
NEW M1 ( 1417080 1579510 ) ( * 1579760 )
NEW M2 ( 1411480 1579760 ) VIA12_2cut_N
Hi Greatrebel,
What you pasted comes from NETS section. You need to check PINS section.
