kalbun
Full Member level 2
- Joined
- Oct 2, 2010
- Messages
- 134
- Helped
- 37
- Reputation
- 74
- Reaction score
- 36
- Trophy points
- 1,318
- Location
- Firenze, Italy
- Activity points
- 2,114
I am currently designing my first RF PCB (well, not the first exactly, let say the first serious RF PCB).
I would like to ask a couple of suggestions.
1) The antenna path is 50 Ohm. According to microstrip calculation, the trace should be 3mm width for a standard FR-4 PCB with 1.6mm height, but only 1.45mm is the PCB height is reduced to 0.8mm.
So I plan to use a 0.8mm PCB, this should also reduce VIA parasitic inductance and capacitance.
In your experience, is this a good choice? Are there drawbacks?
2) Looking at other PCBs, I noticed that VIAs are always put very near to the pad, but not inside. For room reasons, I plan to put VIAs inside the pad. Again, is that a good choice? If not, why?
I am talking about VIAs that connect pads to ground plane.
3) I would like to use PCB coils for the filters, but currently I only found formulas valid if there is no ground plane below the coil. Does anyone can point me to more general formulas?
Thanks
Thanks
