walter60613
Newbie level 2
hi guys ,i need all your help
i simulated the 14.4MHz Bilayer rfid antenna in CST,and now I try to put a IC(Load modulation resistance=1.1 kohm,input capacitance=24pF).
QUESTION
1.if i want to simulated the IC in this antenna,how to design my port?(I always use discrete edge port,Impedance is 50ohms, but now put in the IC maybe set is different)
2.I use inductance values into the equation to conversion capacitors need 21.4pF, I put the capacitor in parallel with a 50 ohm Port, target frequency is 14.4MHz, s11 reasonable to say that the results would coupling in 14.4MHz but i didn't have.
3.Why I cant run H-field and surface-current?
the monitor current(f=14.4MHz) is only available for dielectric or magnetic losses and will be ignored.
the monitor surface-current(f=14.4MHz) is not supported and wil be ignored. Please define an H-Field and Surface current monitor instead.
if you dont understand what i say or you need cst antenna designed file you can message to me,thanks:thumbsup:
QUESTION
