some problem in the rpm code for gettting the dutycycle in the OCR
sangeetha sangu
hi, can any one please help me with this code we are not able to sortout were the overflow is happening we have tried a lot to sort it out.
This program was created by the
CodeWizardAVR V2.60 Evaluation
Automatic Program Generator
© Copyright 1998-2012 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 4/23/2013
Author :
Company :
Comments:
Chip type : ATmega8L
Program type : Application
AVR Core Clock frequency: 1.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
#define P_GAIN
#define I_GAIN
#define D_GAIN
#define dt
#define tim_freq 1000000
#define teeth 12
// Declare your global variables here
int set_rpm=0,previous_error=0;
int error, feedback_rpm,output;
int D_error=0,I_error=0;
int j,rpm;
unsigned int c_rpm,p_rpm=0;
unsigned long int count;
// Timer1 overflow interrupt service routine
interrupt [TIM1_OVF] void timer1_ovf_isr(void)
// Place your code here
j++;
return;
// Timer1 input capture interrupt service routine
interrupt [TIM1_CAPT] void timer1_capt_isr(void)
c_rpm= ICR1;
if(j)
count=(int)((65535 - p_rpm)+((j-1)*65535)+c_rpm);
else
count=(c_rpm - p_rpm);
rpm = (60*tim_freq);
rpm = (rpm/(teeth * count));
feedback_rpm=rpm;
j=0;
p_rpm=c_rpm;
// Timer2 overflow interrupt service routine
interrupt [TIM2_OVF] void timer2_ovf_isr(void)
PORTC = 0x0ff;
// Timer2 output compare interrupt service routine
interrupt [TIM2_COMP] void timer2_comp_isr(void)
OCR2=(5*count/1000)*255;
PORTC =0x00;
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=Out Bit2=In Bit1=In Bit0=In
DDRB=(0<<DDB7) | (0<<DDB6) | (0<<DDB5) | (0<<DDB4) | (1<<DDB3) | (0<<DDB2) | (0<<DDB1) | (0<<DDB0);
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=0 Bit2=T Bit1=T Bit0=T
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
// Function: Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRC=(0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
// State: Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTC=(0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=(0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: 1000.000 kHz
// Mode: Normal top=0xFFFF
// OC1A output: Disconnected
// OC1B output: Disconnected
// Noise Canceler: Off
// Input Capture on Rising Edge
// Timer Period: 65.536 ms
// Timer1 Overflow Interrupt: On
// Input Capture Interrupt: On
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (1<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (1<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Mode: Fast PWM top=0xFF
// OC2 output: Non-Inverted PWM
// Timer Period: 0.256 ms
// Output Pulse(s):
// OC2 Period: 0.256 ms Width: 0 us
ASSR=0<<AS2;
TCCR2=(1<<PWM2) | (1<<COM21) | (0<<COM20) | (1<<CTC2) | (0<<CS22) | (0<<CS21) | (1<<CS20);
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(1<<OCIE2) | (1<<TOIE2) | (1<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (1<<TOIE1) | (0<<TOIE0);
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
// Analog Comparator initialization
// Analog Comparator: Off
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
SFIOR=(0<<ACME);
// ADC initialization
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
// SPI initialization
// SPI disabled
SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0);
// TWI initialization
// TWI disabled
TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE);
// Global enable interrupts
#asm("sei")
set_rpm =100;
previous_error=set_rpm-feedback_rpm;
while (1)
error = (set_rpm - feedback_rpm);
D_error = (error - previous_error)/dt;
I_error +=(error)*dt;
output = (P_GAIN * error)+(I_GAIN * I_error)+(D_GAIN *D_error);
previous_error = error;
You declare some variables as unsigned. I don't know for certain if this is the cause of your overflow, but my experience is that it is less confusing when I stick with signed variables.
This means that when I have a one-byte variable ranging between zero and +127, and one day I realize its value could possibly go over 127, then I bump it up to a two byte variable.
The same if its value could ever go negative, accidentally or deliberately. I forget whether that causes an error, but it ought to.
From what I understand, the calculating routines handle signed variables in a more straightforward manner. On the other hand, mixing signed and unsigned may conceivably have a bug somewhere.
