some parameter after set_scan_configuration
bendrift
Member level 4
Member level 4
i saw a dft script of DFT compiler ,and i am not familiar of some parameter after set_scan_configuration,who can tell the real meaning of these parameter and the real aim in DFT insertion?thanks:)
set_scan_configuration -clock_mixing mix_clocks
set_scan_configuration -internal_clocks false
set_scan_configuration -internal_tri disable_all
set_scan_configuration -bidi_mode input
set_scan_configuration -dedicated_scan_ports false
set_scan_configuration -rebalance true
set_scan_configuration -disable true
set_scan_configuration -hierarchical_isolation true
set_scan_configuration -route true
set_scan_configuration -route_signals all
not scan_enables
You can find every command in the DFT Compiler Scan Synthesis user guide.
I have uploaded it for you.
configure scanning mf3228
thank u for ur help
i will check it in the userguide u upload for me :)
test my point
Added after 21 minutes:
thank u the paper
and i am the beginner fo dft learning
Test my post!
Thanks for your sharing.
I cannot find this user guide under the related directory of design compiler.
dc5030 setup scanning
I used the command for [design vision], latest version from dc_shell, but it didn't work. The report are:
design_vision> set_scan_configuration -methodology partial_scan
Error: unknown option '-methodology' (CMD-010)
Error: extra positional option 'partial_scan' (CMD-012)
did someone know the command that i can use?
thanks before
(cmd-012) error
thanks before
u can get help in the user guide.
cmd-012
i can't found the equivalent syntax for [-methodology partial_scan]
i just found that it can be tested with scan_group
i used simple syntax that has been provide in the user guide but it end up with this error
Error: Cannot run DFT design rule checking on unmapped design
Error: Could not run pre-dft design rule checking. (TEST-1313)
Information: Scan routing is not complete. Signals 'serial or scan_enables' need to be routed. (TEST-899)
i try to remap with command
set_dft_configuration -fix_set enable
but it doesn't work either.
do you have any idea what happen?
if anyone have a simple script for scan_group for example?
