some interview questions.........
rakesh_aadhimoolam
Full Member level 4
hello.........
1) if i have two chip design (two FPGA).what timing characteristic of each chip would i need to know in order to compute max. frequency at which data can be transferred between two chips...
2)how can i minimize the required external setup time of internal pin...........
3)what timing constraint am i checking if i compute minimum path delay from external input to input of register.......
bigrice911
Member level 3
(1) chip 1 setup time and chip 2 hold time
bansalr
Full Member level 3
offset in and offset out of both the FPGA
Use IOB flip flop to register the data at the output.
offset in after
