jasonc2
Full Member level 4
I have no real experience laying out pcbs and I have no specific project or requirements in mind these are general questions. The circuits I have in mind are analog circuits with signals of varying frequencies and a single common ground for all components and DC power. The general goal is to reduce external emi effects as well as internal noise. I realize some of these questions may not have simple answers, in which case references to good reading material would be greatly appreciated.
- For a single layer board its simpler to route it if I just draw a big copper rectangle for grounds and run all the power and signal traces through it. Is this the way to go or is there a reason to use "normal" traces for grounds instead?
For a 2-layer board with through-hole components on the "top" layer:
- Should the ground plane be on the bottom layer, or on the top with power/signal traces on the bottom?
- Is it better to run all power through the ground layer or on the signal layer?
- If I have to run a trace through the ground plane to route the board, should I choose a signal trace or a power trace?
- If I have to run a trace through the ground plane, are there any considerations related to making cuts in the ground plane re: creating bottlenecks in / increasing distance of the ground path through the plane?
- Is it preferred to use existing through holes instead of vias where possible?
- Is there any reason why I'd want to have a power plane and traces for ground instead of a ground plane and traces for power?
Also can anybody recommend a good resource for how signal frequencies affect pcb design choices?
Thanks!
Thanks!
