solving setup time violation
vivek
Member level 4
hi
Suppose that im in my design one of the flops is giving setup time violation.
What are the ways in which i can solve it?
how much is the violation ?
u can swap with low delay sequential cell .
1.over-constrain the design and re-synthesis.
2.pipeline the design in your code
hi
if i had got the violation in one of my gate level simulations, what kind of changes should i do in the code? also can u explain how i can pipline my design or over constrain it? Can you give a sample code?
Solution is:
1. slow down the clock
2. delay the clock by assert a buffer.
3. choose another FF to avoid violation.
Yun Lin said:
Solution is:
i have a question about the 2nd solution. Will it cause other timing violations for a synchronous design ? when we do the dc, don't we think the clock network is ideal?
1) if the flops input is a asynchronous input, you can disable this flop's
setup checking, that's safe.
2) if the flops input is synchronous, you can:
set DC constraint more stringent.
redesign your code to speed logic.
skew related clocks. (bad method, but sometime can help)
vivek said:
hi
(1)size up=> if PR congestion, then
(2)change logic=> doesn't work, then
(3)make latency of CLK=>doesn't work, then
(4)make more pipeline stages=>doesn't work, then
(5)re-coding
you can use a fast lib to resynthesis the rtl
you can use two method:
1) strengthen your DC constraints.
2) re code your rtl and resynthesize.
best regards
vivek said:
hi
Increase compile effort
Repartition design
Insert a delay buffer
Use a faster technology library
Go back to code
relax constrains in your design and re-synthesis the codes.
