solving polynomial in mcu
shaz
Member level 4
Member level 4
hi, for thermocouple linearization i learned i need to use polynomials which can give me correct results, for example, in case of R-TYPE thermocouple for temperature lying between 250-1200 Celcius,
Temp.= 1.334584505E+01 + 1.472644573E+02 x V + -1.844024844E+01 x V^2 + 4.031129726E+00 x V^3 + -6.249428360E-01 x V^4 + 6.468412046E-02 x V^5 + -4.458750426E-03 x V^6 + 1.994710149E-04 x V^7 + -5.313401790E-06 x V^8 + 6.481976217E-08 x V^9 + 0.000000000E+00 x V^10
where V is thermocouple EMF voltage in mV
lets say voltage read is V=6.157mV, then temperature is, (using above equation)
Temp.= 1.334584505E+01 + 1.472644573E+02 x 6.157 + -1.844024844E+01 x 6.157^2 + 4.031129726E+00 x 6.157^3 + -6.249428360E-01 x 6.157^4 + 6.468412046E-02 x 6.157^5 + -4.458750426E-03 x 6.157^6 + 1.994710149E-04 x 6.157^7 + -5.313401790E-06 x 6.157^8 + 6.481976217E-08 x 6.157^9 + 0.000000000E+00 x 6.157^10
=> Temp = 649.9 'Celcius ~ 650 'Celcius
(for refrence i'm attaching R-type thermocouple output chart, linearization coefficents are also given in it, at bottom)
friends please advise me how can i solve this polynomial in C programming of micro-controller because using assembly it seems to be something like impossible. I can use Hi-tech C (if i plan to use PIC micro-controller PIC16F877) or Keil C51 (if i plan to use 8051 core micro-controller, like 89c52), which one do u advise.
i'll honour any help, any suggestion you advise.
thanks
future
Newbie level 6
Newbie level 6
Re: solviing polynomial in mcu
Pre-compute a table for all possible ADC readings you have, for example:
8bit ADC will give a 256byte table.
shaz
Member level 4
Member level 4
future thanks, but that wont help cause i'm using different types of thermocouples and R-type (which i discribed above itself goes upto 1768 degree celcilus which can only be handled by a 12-bit adc, (consediring resoultion=1) so feeding so many values i don't think so it's possible.
BabyTiger
Full Member level 2
Full Member level 2
Please see Application note from MicroConverter from Analog Device. They have source code and document in MCS-51.
shaz
Member level 4
Member level 4
BabyTiger can u please provide the link
artem
Turkey
Search google for :
numerical method to solve polynom
ravimarcus
Full Member level 4
Full Member level 4
Bangalore, INDIA
Shaz - Use double table for lookup. Use the lower ADC value on one table and upper ADC value on another. Merge the result data and you have a linearised 12/16 bits value. It works :)
Off course, you will need a large amount of memory to store all the values. Either use the internal program memory to store or use a SEEPROM to store the values.
Cheers
Ravi
Added after 4 hours 11 minutes:
Here is a double lookup table method to linearise or convert 12/16 bits to another set of 12/16 bits.
Cheers
Ravi
artem
Turkey
shaz, i appologise for mistake in my previous post . If you know the polynom, you can write a simple C code to implement .
Use double types when coding formula calculation.
Do these compilers for mentioned micros support double ? Could you check that ? If not - try float, and test got values against double types as :
Just use conventional compiler for PC and write polynom formula with double and float , then test difference for each input-output pair values and note maximum difference. If it is acceptable - go ahead with float.
alzomor
Advanced Member level 2
Germany
Hi
You can check on the net for Cordic.
Cordic is a method to implement complex math with just Add and shift.
It may help
Salam
Hossam Alzomor
www.i-g.org
rauol
Full Member level 6
Full Member level 6
India
will a 8 Bit MCU be sufficiant for this kind of Math or you require a 16 Bit version.
creative_35
Full Member level 1
Full Member level 1
Under Mango Tree
with fingers we can count up to 10 and for counting 20 what we will do? count once again or borrow some one's fingers?
yazou35
Junior Member level 1
Hello,
you can simplify the problem by making a linearization of your high order polynomials by using lower order polynomials on smaller intervalls.
I send here a matlab program linc5 that make linearization of sensor data into polynomials. You can input the polynoimial order and the max accepted approximation error. There are two examples file, tc_b.dat for a thermocouple type B and pt46.dat for a platinum 46 ohm sensor.
I hope this will help you.
nebisman
Full Member level 4
Full Member level 4
There are some direct functions in hitech C compiler. As far as I remember they are hardly optimized and I thik that their computtion time isn't so long
Look at this,...
sky123
Junior Member level 2
To be honest, pre-computing is the way to go, otherwise you have include a maths library to handle these floating point numbers. a 1Mbit serial flash only costs a dollar or two, and can store a whole range of pre-computed tables, and will only use a couple of I/O pins from your microcontroller. Then you can dynamically select the one closest to your needs.
Another way is to try and scale your numbers, so that you can perform integer arithmetic - not always possible, depending on the complexity of the calculations.
