Solutions for I2C bus level shifter
rommelm
Member level 1
I have this project that I need to Level shift a I2C bus from 1.65V to 6.5V.
I'm planning to use MOSFET as level shifter... do you have other better IDea...
also if you have a driver, or controller that you can recommend...
with my speed requirement, I am but limited to FPGA only. PIC can operate to a mere 1MHz only..
My specs:
1. around Max 20MHz operation[To be used for testing I2C device]
mosfet level shifter
Have a look here (page 7 and on)
Have a look here
This guy does some other cute things using above AppNote
http://delphys.net/d.holmes/hardware/hardware.html
This is a Phillips chip bot only doing levelshifting betveen 1v..5v
Hope this helps out
Ohh...
Btw: About Pic running 1Mhz.
Atmels Mega8 or 16 or 32 runs at true 16Mhz , and have TWI (I2C) hardware interface
/Bingo
level shifter i2c
Thanks BINGO,
Thats the approach I'm planning to take...
right now I am we are considerind the BSN20 of philips...
I was wondering if other guys have a better IDea on how to solve my problem.
so far, using mosfet is the best.....
i2c level
@rommelm
Did you have a look at the Atmel chips ??
The new Mega48/88 runs at 20Mhz genuine Risc giving 20 MIPS , most of the Megas have I2C hardware support , called TWI (Two Wire Interface) because Phillips owns the I2C name.
/Bingo
i2c level shifting
Pericom and On semiconductor does some good level shifters.
level shifter for i2c
Hello again Bingo,
I already checked the Atmel chips but the bus speed of the TWI is upto 400KHz only.
Can we drive it upto 20Mhz?
i2c level shifter mosfet
I want a cheap level shifter from 3 volts to 5 volts. Can any body suggest me.
i2c level shift
I ordered MAX3002 (check also MAX3001 and MAX3003) for my new project. They are quite cheap (2.3$) and have 8 independent bi-directional channels. They are pretty nice - you don't have to bother about directional control, just put them between.
Also, Analog Devices have new IC converter with similar features.
level shifting fet
Try searching at T.I.
