mpardinho
Newbie level 5
i use this code but then i compile occurs some errors
i help me with erros
DataPin equ 0x06 ;PIC Pin
ClockPin equ 0x07 ;PIC Pin
Char equ 0x35 ;buffer
BitCounter equ 0x36 ;number of bits to read
GetScanCode
bsf STATUS, RP0 ;select bank 1
bsf TRISB, DataPin ;set pins as input
bsf TRISB, ClockPin
bcf OPTION_REG, NOT_RBPU ;pull-ups are enabled
bcf STATUS, RP0 ;select bank 0
call ClockWait ;wait for Pull up to take effect and keyboard to pull clock low
;--- Read Data Bits ----
ReadKey
clrf Char ERROR
movlw .8 ;bits to read
movwf BitCounter
ReadChar
rrf Char ERROR
bcf Char, 7 ;default value is 0
call ClockWait ;wait for clock to go high then low
btfss PORTB, DataPin ;read Data
goto Next ERROR
bsf Char, 7 ;Data is High ERROR
Next decfsz BitCounter
goto ReadChar ;read next Data Bit
call ClockWait ;Parity Bit
call ClockWait ;Stop Bit
;Pull Clock Line Low (keyboard will buffer any further keystrokes)
bcf TRISB, ClockPin ;set clock line as output
bcf PORTB, ClockPin ;set clock line low
movf Char, W
return
ClockWait
btfss PORTB, ClockPin
goto ClockWait
ClockWait2
;wait for clock to go low
btfsc PORTB, ClockPin
goto ClockWait2
return ERROR
GetScanCode
bsf TRISB, ClockPin
ReadKey
clrf Char ERROR
movwf BitCounter
ReadChar
rrf Char ERROR
goto Next ERROR
movf Char, W
return
ClockWait
goto ClockWait
ClockWait2
goto ClockWait2
return ERROR
