elk84
Newbie level 1
- Joined
- Jan 12, 2015
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 13
Hello,
I have a 12 volt solenoid which I have actuated using a standard benchtop power supply (30V and 5 A). When I supply ground to one lead, and 12 VDC to the other, the solenoid actuates as expected. However, I notice that the power supply voltage drops from 12 VDC to 6 VDC during the actuation while pulling 700 mA. If I put a 33 ohm resistor in series with the solenoid coil, the solenoid actuates and the power supply remains at 12VDC while pulling about 275 mA as expected. Why is this happening? The coil itself has a resistance of about 5 ohms, why does the power supply only maintain its 12 V when an extra 33 ohms are placed in series with the solenoid? I would like to actuate the solenoid while not affecting the voltage of the regulated power supply. Any insight would be helpful!
Thanks!
Thanks!
