eem2am
Banned
Soldering tiny SMD's
hello , i wish to solder small Surface Mount devices with pin to pin spacing of 0.65mm. There are 14 pins.
How do i do this.?
Small solder iron tip just dont get enough heat to it.
but big tip solder the pins together.
Do you say that the ONLY way to do this is to "blob" solder all the pins together and then try and mop up the excess with 0.9mm solder braid?
(Please also do you know what uis "drag soldering")
How do i do this.?
