Hi all. quick question:
Is there any danger in soldering directly to battery terminals in the short and long term? i ask because i want to make use of the bl-5c lithium ion battery for a project. it is possible to **broken link removed** battery contacts for this particular battery but they are very expensive(i bought some a while back for cheaper but cant find any now). This guide suggests its possible but i would like to hear some opinions. it seems that it comes down to thermal damage but if you are able to get the process done swiftly then it should be ok. I have tried it out and it seems to work ok from what i can tell....
Thanks for any possible reply's,
Danny
2. Soldering temp may exceed 200C and the temp may damager the battery (there are plastic insulators /spacers in the battery).
3. If you have a spot welder, a thin connection may be welded with little heat. Because the welding will be over in less than a second, the total heat used will be perhaps less.
4. Perhaps you can make a temp holder? Li batteries are rather fussy; you need to pay attention to everything you do them!!
bl-5c is an enclosed mobile phone battery, the contacts are not actually "battery terminals", they connect to the Li-ion cell by wires or thin metal stripes.
Soldering to the gold plated contacts is easy and won't necessarily overheat the battery. Thus it may be acceptable in this special case.
This did come to mind actually. Thanks for that its good news as those little connectors are very tricky to get hold of unless you are happy paying through the roof or want a 1000 of them!
