solar strret light,,solar 10watt,battery 12v 7.2AH,,sensor motion,LED 4watt,
jo98
Newbie level 2
hi,,want to ask does battery 12v 7.2AH can light up LED4watt????thank you
the power supply is too much for a single LED but can you be more specific are you using an array of lights and stuff like that
Yes, 7,2Ah 12V can power 4W LED.
This battery 7,2Ah is for max load up to 50W no more. You can power one LED module of 50W on it, and will light.
I use often single 9W warm white led for hand held light.
There is LED modules of 100W, 200W 500W,....
thanks tpetar..i can light up my LED with no problem..:-D
btw,,can you guys tell me how to switch sensor motion as on and off???tq
Sensor motion what
if you want to trigger a sensor there or just detection of motion using sensor
Kindly post new thread for different topics
See the specifications of the Voltage and current rating of your said LED. Powering a LED is always good with a current controlled source like a driver. You may also use a resistor in series to the LED.
Cheers
