Software UART Problem on PIC18F452
saeed_pk
Full Member level 4
Islamabad, Pakistan
software uart
I va tried bitbang procedure given in samples of PICC on PIC16F877A , when i tried to utilized it for PIC18F452 it does not work
Compiler Used :
Hi-Tech PICC for 16F877A
Hi-Tech PICC-18 for 18F452
please help ..
 *	Serial port driver (uses bit-banging)
 *	for 16Cxx series parts.
 * 	IMPORTANT: Compile this file with FULL optimization
 *	Copyright (C)1996 HI-TECH Software.
 *	Freely distributable.
#include	<pic.h>
 *	Tunable parameters
/*	Transmit and Receive port bits */
#define SERIAL_PORT	PORTC
#define SERIAL_TRIS	TRISC
#define	TX_PIN		6
#define RX_PIN		7
/*	Xtal frequency */
#define	XTAL	4000000
/*	Baud rate	*/
#define	BRATE	9600
/*	Don't change anything else */
#define SCALER		10000000
#define ITIME		4*SCALER/XTAL	/* Instruction cycle time */
#if BRATE > 1200
 #define	DLY		3		/* cycles per null loop */
 #define	TX_OHEAD 13		/* overhead cycles per loop */
#else
 #define	DLY		9		/* cycles per null loop */
 #define TX_OHEAD  14
#endif
#define	RX_OHEAD	12		/* receiver overhead per loop */
#define	DELAY(ohead)	(((SCALER/BRATE)-(ohead*ITIME))/(DLY*ITIME))
static bit	TxData @ (unsigned)&SERIAL_PORT*8+TX_PIN;	/* Map TxData to pin */
static bit	RxData @ (unsigned)&SERIAL_PORT*8+RX_PIN;	/* Map RxData to pin */
#define	INIT_PORT	SERIAL_TRIS = 1<<RX_PIN				/* set up I/O direction */
void
putch(char c)
	unsigned char	bitno;
#if BRATE > 1200
	unsigned char	dly;
#else
	unsigned int	dly;
#endif
	INIT_PORT;
	TxData = 0;			/* start bit */
	bitno = 12;
	do {
		dly = DELAY(TX_OHEAD);	/* wait one bit time */
		do
			/* waiting in delay loop */ ;
		while(--dly);
		if(c & 1)
			TxData = 1;
		if(!(c & 1))
			TxData = 0;
		c = (c >> 1) | 0x80;
	} while(--bitno);
NOP();
char
getch(void)
	unsigned char	c, bitno;
#if BRATE > 1200
	unsigned char	dly;
#else
	unsigned int	dly;
#endif
	for(;;) {
		while(RxData)
			continue;	/* wait for start bit */
		dly = DELAY(3)/2;
		do
		while(--dly);
		if(RxData)
			continue;	/* twas just noise */
		bitno = 8;
		c = 0;
		do {
			dly = DELAY(RX_OHEAD);
			do
			while(--dly);
			c = (c >> 1) | (RxData << 7);
		} while(--bitno);
		return c;
char
getche(void)
	char c;
	putch(c = getch());
	return c;
and main file is
#include <stdio.h>
#include <pic.h>
/* A simple demonstration of serial communications which
 * uses the bit-banging implementation of a serial communications.
 * Useful for PIC16Cxxx series of devices, or if USART is already
 * in use. */
void main(void){
	unsigned char input;
	INTCON=0;	// purpose of disabling the interrupts.
	printf("\rPress a key and I will echo it back:\n");
	while(1){
		input = getch();	// read a response from the user
		printf("\rI detected [%c]",input);	// echo it back
pic18f software uart
Hi
Looks at IAR site www.IAR.com for application note
there is a nice application note on software uart with c language code
With a small effort it can be converted to work on any micro
All the best
Bobi
