asking
Full Member level 5
- Joined
- Sep 21, 2010
- Messages
- 279
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Activity points
- 3,377
I am trying to make some counter based on the input (logic 1, 5v) signal. when the Proximity will sense the object pass by it will give output 1 (logic 5v) for the time it detects object. Then it will be 0 again. So i am trying to write one simple program to increment counter, but i am facing some issues.
1) Counter should not increment continuously @ MIPS rate. (i really don't how to use Software interrupt.) (it should count 1 by 1)
2) i have made little program for just testing but i am unable to use software interrupt. is this correct way to keep my code in Main {} or i should use it in While(1) loop for continous monitoring ?
3) can i use Void Interrupt () { ISR } for this ? or it should be only use with hardware interrupt like RB0/INT, TMR0IF etc..
OR
Please throw some light on software interrupts. Please provide some software interrupt based some examples.
Thanks
if (PORTA.F1 == 1)
VAR1 = 1;
If (VAR1 == 1 && PORTA.F1 == 1)
COUNT = COUNT + 1;
VAR1 = 0;
OR
void Interrupt()
if (PORTA.F1 == 1)
VAR1 = 1;
if (VAR1 == 1 && PORTA.F1 == 1)
COUNT = COUNT + 1;
VAR1 = 0;
short int COUNT = 0, VAR1 = 0, VAR2 = 0;
void main()
CMCON = 7;
TRISA = 0b00000001;
TRISB = 0b00000000;
OPTION_REG.F7 = 0;
PWM1_Init(38000);
PWM1_Set_duty(150);
PWM1_Start();
if (PORTA.F1 == 1)
VAR1 = 1;
COUNT = COUNT + 1;
VAR1 = 0;
while (1)
// should i use polling here or in main loop ? please explain i am confused between void main() and while(1).......
Thanks
