rajaselvamj
Junior Member level 2
Can any one suggest good software for C to HDL converter
May be. You can also use System-C or System Verilog language in logic programming, it's very near to C. But it won't allow you e.g. to run a program coded for a µP on a FPGA. That's not a matter of syntax but of semantics. Programmable logic don't work in the same way as a processor. You have to understand it's way of operation and then code a problem in a different way.I think there are some software for c to HDL converter
