Socket Programming pls help
ashuisgolu
Junior Member level 2
Hello,
I am new to socket programming. I hav read some basics about socket programming. I want to implement a client server program in windows platform using visual C++. How will i start about? I downloaded certain programmes from internet but cannot make out how the code works. Is there any good material that explains socket code line by line?
What is the type of cable that is used to connect client PC to server PC?
Pls help me
Thanks and regards
You can use any cable, depends upon your application that what interface it uses. Most of the time it is ethernet.
