soc encounter installation in linux
eda_wiz
Advanced Member level 2
hi all,
can any one tell me how to set the path variables in Linux after installing soc encounter
tnx
lcg22
Member level 5
cds_plat
edit your .bashrc file in your home directory.
kwkam
Full Member level 5
Somewhere on earth
how to install soc encounter
setenv SOC_HOME /install_directory
set path = ( ${SOC_HOME}/tools/bin \
${path} )
FNK
Member level 3
Don't I need to point to License file? Does SOC requires lmgrd or simply LM_LICENSE_FILE variable..
Can plz someone guide me.
thanks
fiber7
Member level 1
how to install cadence encounter
LM_LICENSE_FILE is ok....
If you want you can also use the CDS_LIC_FILE variable instead......
Cheers.
Fib.
FNK
Member level 3
how to install cadence soc encounter
Thanks; it is working.
By the way; does anyone know how to configure cdsdocs (online documentation) when using both IC5 and SOC.
Secondly, I think USR file contains whole BASE with some inclusions .... so can one install SOC without BASE file?
FNK
Member level 3
encounter 52 install
I have a few queries. Hopefully someone can answer them.
What is the difference between BASE and USR files?
Do I only need to update the environment variables to point to the USR installation directory in order to use the USR pack?
What is the latest USR pack?
I saw in the installation directory, a directory named Buildgates. Can we use Buildgates inside SOC?
Thanks
CatKing
Full Member level 3
encounter license
I don't think the USR included all Base files, it's service release only, maybe can run, but i'm not sure all the functions will run correctly or not. Check the install file sizes of Base release and USR release, you will find the Base release is the biggest.
johnnyh
Member level 1
cadence soc encounter installation
setenv SOC_HOME /Cadence/SOC22
set BINDIR = /Cadence/SOC22/tools.sun4v/bin
set FEBINDIR = /Cadence/SOC22/bin
set CDS_PLAT = `${BINDIR}/cds_plat`
setenv ENCOUNTER /Cadence/SOC22
setenv SE_HOME /Cadence/SOC22/tools/dsm
setenv PKS_HOME /Cadence/SOC22/BuildGates/v05.00-p008
setenv PLATO_HOME /Cadence/SOC22/tools/plato
#setenv CADMOSHOME /Cadence/SOC22/CADMOS40/tools/pacific
setenv CADMOSHOME /Cadence/SOC22/CADMOS40/tools/celtic
setenv SIMPLEX_HOME /Cadence/FireIce_QX31
setenv LDV_HOME /Cadence/LDV40
setenv OPUS_DIR /Cadence/IC5.0
setenv TNT_INST_DIR /Cadence/SOC22
set path = ( $OPUS_DIR/tools/bin $OPUS_DIR/tools/dfII/bin $LDV_HOME/tools/verilog/bin $path )
set path = ( $SE_HOME/bin $SE_HOME/fe/bin $PKS_HOME/bin $PLATO_HOME/bin $PLATO_HOME/../bin $path )
set path = ( $ENCOUNTER/tools/bin $ENCOUNTER/tools/fe/bin $CADMOSHOME/bin $path )
set path = ( $SIMPLEX_HOME/bin $path )
FNK
Member level 3
setenv soc_home
What about Buildgates present in the installation directory. Can we use it? Does it require setting some environment variables?
nozone
Member level 3
setup soc encounter
what's the improvement from 2.2 to 3.1, I can only find the 2.2
nanako
Member level 5
installation of soc encounter
what are the features required to run the software ???
eins99
Full Member level 1
"set BINDIR = /Cadence/SOC22/tools.sun4v/bin
set CDS_PLAT = `${BINDIR}/cds_plat`"
can you explain the difference between "set VAR_XXX = ..." and "setenv VAR_YYY ..." ? what is the first type meaning and where is it used for ?
Is there an equivalent form in BASH shell ?
Atre
Full Member level 1
Eindhoven, the Netherlands
cadence first encounter install
The form with set var=... or setenv var is used in CSH.
For bash, you can try:
var=...
export var or
directly export var = ...
Hope this helps! :wink:
elektrom
Full Member level 2
linux install soc encounter
Thanks
What should I do with USR pack? Just overwrite BASE by USR?
hqqh
Full Member level 4
Hello,
if you execute ./Setup.sh from the USR release and install the products you want, the necessary files will be installed and the unnecessary files will be removed.
you need the baseline and the usr release for this installation.
greetings,
hqqh
maniasonic
Member level 1
cadence encounter install
who can tell me what tools are included in SOC22? Does it is a set of layout tools or FE+BE tool set?
gerryhsu
Full Member level 3
cadance encounter install
Basically it's a Place and Route tool as same as Apollo, Astro from Avant! or Blast from Magma. The name of the tool is not important because it change all the time, what it can do and what do you want to do is more important.
CatKing
Full Member level 3
what is the present version of soc encounter
it's more than P&R, plus RTL2GDS flow, Fast FloorPlanning.
gujm
Newbie level 5
soc encounter bashrc
Products included in Release- SOC32
Product # Product Name Version
FE100 Cadence(R) First Encounter Ultra 2003.2
FE150 Cadence(R) NanoRoute Ultra SoC Routing Solution 2003.2
FE200 Cadence(R) SoC Encounter 2003.2
FE300 Nano Encounter 2003.2
FE71 Clock Tree Synthesis Option to First Encounter Classic or First Encounter 2003.2
FE76 First Encounter Classic 2003.2
RA100 Route Accelerator Multi-Threaded Route Option 2003.2
