Feb 27, 2017 #1 abhishek.2138 Full Member level 2 Joined Dec 21, 2013 Messages 131 Helped 0 Reputation 0 Reaction score 1 Trophy points 1,298 Activity points 2,383 which type of capacitor used for snubber in flyback smps of around 20watts ?
Feb 27, 2017 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,155 Helped 4,868 Reputation 9,757 Reaction score 5,535 Trophy points 1,393 Activity points 168,327 Hi, no voltage, no current? No circuit? Klaus
Feb 28, 2017 #3 abhishek.2138 Full Member level 2 Joined Dec 21, 2013 Messages 131 Helped 0 Reputation 0 Reaction score 1 Trophy points 1,298 Activity points 2,383 Input - 230Vac (15% tolerance), 50 Hz Output- 24V, 0.5A Device used- NCP1014AP06 (in built MOSFET of 700V & controller 65 KHz freq.) want to know ceramic or film capacitor to be used for clamp & for snubber. Here I am concerned with clamp now (for NCP1014AP06) but also want to know capacitor type for snubber. Flyback topology used with no auxilary winding...( No aux winding needed for NCP1014 upto 14W) Datasheet--- View attachment NCP1010-D.PDF Last edited: Feb 28, 2017
Apr 21, 2017 #4 R rohithkrishnan Junior Member level 3 Joined Aug 10, 2016 Messages 31 Helped 7 Reputation 14 Reaction score 7 Trophy points 8 Location India Activity points 189 You can use a ceramic capacitor which can tolerate upto few 100s of volts. Thanks
Apr 23, 2017 #5 T treez Guest ceramic yes, as in smd is less inductive than most film types.....and smaller......if you shovel your spec into power.com's free PI Expert software it will calculate the entire circuit and bom for you...and tell you the snubber cap part number etc
