pcb glue mask
Howdy,
I am using BoardStation to design boards and had a couple of questions about SMT gluing and glue mask layers. To date, we have been hand assembling our SMT boards (which are mainly low production runs) but I'd like to design for effective automated assembly.
(1) I have been putting via's under SMT components to conserve space but I am concerned that this might interfere with the glue (or visa versa). Is this OK even if a glue dot will be applied in the vicinity of a via?
(2) BoardStation has a glue mask layer that I have been (arbitrarily) setting up to fit comfortably under the components. Is this actually useful or will the board assembly shop just put a dot of glue down in the center of the board? What guidelines should I use for glue mask definition?
The boards we design are relatively low production runs that are modifications for radar. There would typically be a run of 50 - 250 boards on anything we produce.
Thanks much,
swright
