sms based device control
djzbor
Junior Member level 2
hi every body .
I am doing a project on controlling a device using sms. i wan do like this rather than using two mobiles i preferred it to be a mobile and wired telephone.Here is my thought i will connect my wired telephone to the micro controller and the micro controller to devices i wan control.I will send sms to wired telephone ,is there a way of doing it? Or is my mobile can be set to some mode so that the sms message can be sent as voice to the wired telephone ? And when the wired telephone sends back the status of some device in voice is there a means to be changed to sms for my mobile?
joby16
Member level 3
Instead of sending voice message, you can send numbers(0-9, *, #) to the wired phone. If you use a vice chip in the device attached to the phone, you can store and play back the message.
Regards,
Joby
trendzece
Newbie level 2
hi even i'm doin the same proj..
how will the sms be recognized by the microcontroller.
any body havng any source codes
kindly reply
joby16
Member level 3
Hi!,
You have to interface a GSM module to the micro controller to receive the SMS.
keanesiew
Newbie level 5
and how might the interface be? i'm working on the interfacing too to see the response from the modem by sending AT from the microcontroller to the modem..
my connections are
RC6(TX) ---> T1IN(MAX232) ---> T1OUT(MAX232) ---> RXD(MODEM)
TXD(MODEM) ---> R1IN(MAX232) ---> R1OUT(MAX232) ---> RC7(RX)
is this correct?? i'd really appreciate help from those who really know! thanks in advance...
keane
