smps 230V ac/ 24V dc 10A
dawid5255252
Junior Member level 1
Hello all,
At the beginning I want to say, that i didn't make smps before. I wish to construct power supply with following parameters: 24V 10A 240W (around), powered form the mains. The smps will be used to power 24V DC motor. I checked out some forums but couldn't find any scheme. Can someone give me advice from what should I start or are there any existing circuits to avoid designing everything from beginning?
Motor power is 200W, so it's 8.33A. I planned some power loss on transformer, that's why I want to make smps at around 240W
Motor when starting usually use more current than nominal, often even double of nominal current.
I checked it and you are right. It follows that I need smps 230V / 24V 400W.
Can someone help me with adequate schematic?
you can still use the one i posted with little modification it will work.
I think that I can use configuration of SG3525 from your schematic to controll half bridge and I need modify some rest
