MisaghSepehr
Newbie level 6
Hello every one;
I have bought a pair of ST7540 (Power Line carrier modem). I connected it to a host controller( AVR chip) and tried to read its internal register.
when I connected 12.5V supply to circuit, smoke rised from my ST7540 and fired!!!
after this, I checked out if my 12.5V sypply has ripple,but every thing was OK.then I looked at datasheet and found below table of pin specification:
"Vsense pin and CL pin cannot be left foating".
while I floated them!!!
signals I connected to ST7540 from host were: REG_Data , RXD , TXD , RxTx , CLR/T
and gorunded pins: GND , Test1 , Test2 , Vss , SVss , UART/SPI
and VDD was connected to VDC pin, 16MHZ crystal between X1 and X2.
Can Leaving pins Vsense and CL float cause St7540 to fail? what is the reason?
Thank you- M.R Misagh
