Sunny55
Full Member level 3
Hi, i have a very small smd ic and i cannot find the right breakout board for it. I have came across people soldering very thin wires( i do not know what its called) onto smd components. How would that affect the current in and out of the IC as usually jumper wires are used on veroboards and not that thin wires.
In other words, i plan to solder the thin wires on to the smd connectors but not sure if its correct to do so and whether the wires can be used together with jumper wires on veroboard. Pls help.
