SMD parts codes tables needed
Pavka
Junior Member level 2
Russia SPb
smd codes
Where can I find code marking guide for SMD descrete components (transistors & diodes)?
What is the type of these transistors (SOT23 package):
W1P (n-p-n),
W2F (p-n-p)
12W (mosfet),
W2T (zener diode)?
smd 12w
SMD codes:
Regards,
IanP
smd parts
IanP said:
SMD codes:
Regards,
IanP
Thanks, but the link contains very few codes & neither no code of the parts listed.
:?:If anybody can tell the parts in the 1st post, pls, reply.
Regards...
smd code 12w
It seems to be a real jungle, I've been digging in some Philips
databooks and I could only find one: W1P is (or could be) a
BFT92 in SOT23 package. One down, three to go.
You could also take a look here:
And you'll find a lot more if you search for smd markings.
on1aag.
smd code
SMD 12W parts codes help.
Dear friens please help the " 12W " (mosfet,SOT23 package), parts code and pinout.
Thank you
12w smd
Thank you
Hi buddy!
I m sure this's what u looking for : **broken link removed**
It's 2N7002 from NXP (Philips)
w1p transistor
I have two SOT23 parts with the following markings:
B3P1T
B2Q5T
Any idea what these devices are? Thank you.
w1p smd
hi,
i am looking for "A35". it is a diode but i couldnt find the ratings.
regards.
transistor w2t
W1P (n-p-n),
W2F (p-n-p)
12W (mosfet),
W2T (zener diode)?
Hi Pavka have you tried looking at Manufacturers website for codes. Sometimes they will list part of no eg last 4 digits of transistor. Hope this helps.
W1P PMBT2222A SOT23 NPN switching transistors ... PHI
W2F PMBT2907A SOT23 PNP switching transistors ... PHI
David
I'm one of EDAboard!
david@smdok.com
https://www.smdok.com
we offer check-markingcode,PCB-COPY,Chip-decryption service
We providing searching service of smdcodes(also known as markingcode,top mark,marking and package marking). Our database incluses the codes of transistors, diodes, tvs, thyristors, ics, etc. You will be suprised to find many dip components' code and many smd codes those hard to find in the internet or anywhere else. The news is that the database quantity is grouping up day by day. Nomatter easy code or difficulty code, all you need to do is to input codes and search, instead of collecting everyday. Why? Because we, your support team is doing that for you.
