[SOLVED] SmartFusion UART transmit with PDMA
Endre
Newbie level 5
I have the following code which 1st makes an UART transmit with the polled driver function. This works, the message arrives to the terminal ("Welcome! (polled transmit)").
Then it attempts to transmit an other string ("Welcome! (DMA transmit)") with PDMA. Nothing happens, the function returns, but the message is not transmitted.
Here is the code:
static inline void print(const char * msg) {
	MSS_UART_polled_tx_string(&g_mss_uart0, (const uint8_t*)msg);
static void welcome() {
	uint16_t len;
	const char * welcomeDMA = "Welcome! (DMA transmit)\n";
	MSS_UART_init(
		&g_mss_uart0,
		MSS_UART_460800_BAUD, /*MSS_UART_19200_BAUD,*/ /* MSS_UART_921600_BAUD, */
		MSS_UART_DATA_8_BITS | MSS_UART_NO_PARITY | MSS_UART_ONE_STOP_BIT
	print("Welcome! (polled transmit)\n");
	for(len = 0; welcomeDMA[len]; len++);
	/* g_mss_uart0.hw_reg.FCR = 8;	*/ /* ENABLE_TXRDY_RXRDY */ /* already done by init */
	PDMA_init();
	/* PDMA_set_priority_ratio(PDMA_ROUND_ROBIN); */
	PDMA_set_priority_ratio(PDMA_RATIO_HIGH_LOW_1_TO_1);
	PDMA_configure(
		PDMA_CHANNEL_0,
		PDMA_TO_UART_0,
		PDMA_LOW_PRIORITY | PDMA_BYTE_TRANSFER | PDMA_INC_SRC_ONE_BYTE /* uint32_t channel_cfg */,
		PDMA_DEFAULT_WRITE_ADJ
	PDMA_start(
		PDMA_CHANNEL_0,
		(uint32_t)welcomeDMA,
		PDMA_UART0_TX_REGISTER,
		len
	/* while (1); */	/* maybe FreeRTOS damages the DMA? */
What can be the problem?
As I see the source of the DMA transfer must reside in the SRAM. It doesn't seems to be working when the source is in the eNVM.
