small schedduler for pic12c508
gorkin
Advanced Member level 1
brazil
Hi brothers! I need implement the following code in small PIC12C508.
I teste with sucessifull in others devices like PIC12F629 and PIC16F627, but when I compile for PIC12C508 the code not run correctly, anyone have any suggestion?
Thanks a lot and have a nice day or night! :wink:
#include <stdlib.h>
#include <stdio.h>
#define ON 0
#define OFF 1
#define maxtasks 3
#define uchar unsigned char
// Variáveis Globais
uchar tasks = 0;
// Array de tasks, terminador null
void(*x[maxtasks + 1])(void);
// ponteiro de função
typedef void(*fp)(void);
//protótipos
uchar FindTask (void(*fp)(void));
void CreateTask (void(*task)(void));
void DeleteTask (void(*fp)(void));
void task0 (void);
void task1 (void);
void task2 (void);
void task3 (void);
void task4 (void);
void task5 (void);
void CreateTask(void(*task)(void))
uchar n;
if(!FindTask(task))
for(n = 0x00; n < maxtasks || x[n] != NULL; n++)
if(x[n] == NULL)
x[n] = task;
x[++n] = NULL;
return;
void DeleteTask(void(*task)(void))
uchar n;
for(n = 0x00; n < maxtasks; n++)
if(x[n] == task)
do
x[n] = x[n + 0x01];
n++;
while(x[n] != NULL);
return;
uchar FindTask(void(*fp)(void))
uchar n;
uchar tmp;
if(x[n] == fp)
tmp = 0x01;
else
tmp = 0x00;
return(tmp);
void task0 (void)
#asm
NOP
NOP
NOP
NOP
NOP
#endasm
void task1 (void)
#asm
NOP
NOP
NOP
NOP
NOP
#endasm
void task2 (void)
#asm
NOP
NOP
NOP
NOP
NOP
#endasm
void task3 (void)
#asm
NOP
NOP
NOP
NOP
NOP
#endasm
void task4 (void)
void task5 (void)
void main (void)
uchar n = 0x00;
x[n] = NULL;
CreateTask(task0);
for(;;)
while(x[n] != NULL)
x[n++]();
n = 0x00;
Are you shure that it your program fits in 512 btyes??
otherwise .are you correctlt programming the watchdog timer and reset bits ??
Ok Elton, I simulate this code under MPLAB v6 and the C Compiler is Hitech...
When I compile this code, I report the memory map file, In ROM I use 55% and RAM 80%...
Strange...very strange no?
Thanks my brother!
Gorkin
