black-code
Newbie level 5
Hello all,..
I am using l6203 with atmega32 mc to make a speed control for a dc motor by using pwm technique.
1-
I want to ask when i connect the pin of the pwm to the l6203 h-bridge it shoul be connected to the in1 pin of the h-bridge and giving the another in2 pin 0 (reverse the states of in1 and in2 for the opposite direction) and the enable will be always high.
or:
2-
Connect the pwm pin to the enable pin of the h-bridge and make in1 high and in2 low (reverse the states of in1 and in2 for the opposite direction) ??
In my connections i used the second method, i am correct or not??
Hint: my h-bridge burned out many times but i wasn't connect the bootstrap capacitors at pins 4,8 so if applying pwm to the enable pin of the h-bridge may cause a damage to the h-bridge or the missing bootstrap capacitors is only the reason of that problem.
Thanks.
1-
or:
2-
Thanks.
