I am currently limited due to a stroke,. so apologies for misspellings.
I am trying to start on 3 uncomplicated projects, and initially need a CPLD (probably) with
200 Mhz
Less than 2 dozen I/O
Connect ideally to USB
Not going obsolete
Any ideas? I picked an ispMach4032, but Lattice Diamond-3.6 does not seem to cater for it. Do I need another software package? I also have Altera Quartus-15.1, & Anadigm Designer-2.8.0.2 installed in a vm (m$ Vista) , with Xilinx software also on an older box. My pc runs Slackware Linux.
You don't say what this device needs to do. Yes, it's got a small number of I/O, but you don't say whether it needs to blink a light or provide automatic steering for a car. And what do you mean "connect ideally to USB"? Do you mean you need to implement a USB stack? More information is needed to provide an intelligent answer.
It's got a circuit to generate & discriminate FM/FSK using period measurement, and minor glue logic (H-bridge driver, switches read into logic, etc.). I haven't gotten around to implementing usb, or even thought about it. Early stages yet. If I could buy some IP, that would save effort. USB-2.0 Would be plenty, as speeds are slow.
Implementing any USB interface will take up far more resources than are available in a CPLD. Implementing USB 2 would likely involve adding a separate USB PHY to the board. You would be better off simply purchasing a separate USB <--> Serial UART (or SPI) chip like an FTDI FT232 and then implementing UART or SPI functionality in the CPLD to give you the communications interface.
