SMA connector footprint
the_owl
Junior Member level 1
hello everyone,
anyone know the footprint for this SMA connector? I was looking for the footprint for few days but could't found. I would appreciate if u can provide me the footprint for this. Thanks!
can it be a through hole??
no this is Edge Mount Connector... You can use attached SMA Connector for Through hole....
Plz click this link
**broken link removed**[2005.06.30%2009.58.29].pdf
No this will be a Surface mount part. You have to be very careful with this because i think you cannot exceed the board thickness by 1.6 mm (63 mils).
ohh..so the footprint should be on both top and bottom surface as it is edge mounted??
Yes.. if the SMA Is Edge mounted then it should soldered on both top and Bottom side...
