rizwan183
Member level 4
Hello everyone, I am developing a double side pcb. one side is ground and other side is microstrip circuitary to feed the antenna. I need to design the footprints of the connector. i don't understand connectors at all. the throughhole connector got all four pins equal in length. i thought middle pin should be smaller than others or vice versa (how is four pin supposed to connect ground on opposite side while middle is supposed to connect microstrip). I don't want to use the option of middle pin with holes which is theoretical same as throughhole. same is true for edge mount, should i use ground around microstrip feeding point and then connect that ground with vias to the other side of pcb like CPW. detailed answer along with samle guide will be alot help.
sorry if i am being too naive. This is my first pcb.
