[SOLVED] SLV into System Generator Block
ravics
Shangri-la
How can I input std_logic_vector into system generator blocks? Constant block supports fixed, boolean & dsp instructions. Is there any way to force slv as input to another sysgen blk?
I'm not sure I understand your question... any time you us a multi-bit bus in SysGen, it will be std_logic_vector. Otherwise, you can likely meet your needs using a black box.
Reactions: ravics
    ravics
