T
treez
I am designing a two transistor forward converter where the upper fet is driven by a pulse transformer, (fron the controller's gate drive output) but the lower fet is driven on straight from the controller's gate drive output , with no pulse transformer.
........because of leakage in the pulse transformer (its too expensive too wind for the super low leakage required in the pulse transformer)......i intend to put a 1us delay in the track to the lower fet's gate.......in this way, the top fet will come on first....but will suffer no turn-on switching loss as the bottom fet will not yet be on.....the lower fet comes on 1us later, and takes all the switch-on switching loss, but it doesnt matter because the lower fet doesnt have pulse transformer drive and so is fast switched.
The delay will mean the upper fet is also first to turn-off, meaning it will unfortunatley take all the switch-off switching loss, but this is not so bad, because there will be a PNP turn off transistor at the gate of the upper fet....so its switch-off will not be delayed by the pulse transformer's leakage.
Do you think this is a good method?....the 1us delay for the lower fet drive will come via an RC followed by a gate driver chip...the RC being set for the 1us delay.
The converters switching frequency is 85KHz.....do you think this 1us delay will adversely effect the feedback loop?
