Dear Klaus,
Thank you a lot
Exactly, the fully differential output signal has twice the slew rate of individual output signal, as you said, this is the case I have
I should deal with the fact, that the fully differential output can not be treated as two single ended outputs otherwise I will loose the half of my properties values (gain, SR, etc), all my characteristics should be with respect to fully differential outputs to the fully differential inputs.
in the same time, the next stage to the fully differential amplifier must also read the output signals deferentially, again if the next stage is single ended in, then also I will loose the half values.
Dear friends, I have this question please,
In the past I was designing single ended opamp with load connected RL=100K, CL=5Pf
as you know I made a fully differential one based in the previous design, now I have two outputs on each I am connecting RL=100K, CL=5Pf, or do I need to change the load values (like half it) to make the same load condition of the single ended amp
Thank you very much once again
