Slew rate problems at high frequencies
saurabh17g
Member level 2
Bombay
The slew rate of the opamp we consider Vp or Vp-p rite i.e.
SR = 2*pi*fmax*Vp-output
or
2*pi*fmax*Vp-p-output ?
my sine wave is of form Vout = 2.5(1+sin(wt)).
and by this, Slew Rate required for my circuit = 15.7V/us which is less than the one specified in datasheet(17V/us). So, would the slewrate limitation problem occur?
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
Maximum slope of a sine wave is 2*pi*Vp so that is the figure to use, not peak to peak. Bear in mind the values in the data sheet are "typical" and quoted at a specified load so it would be risky to assume you can run so close to the datasheet value. I would like a reasonable margin between what is theoretically required and what the opamp produces.
Keith.
saurabh17g
Member level 2
Bombay
Thanks keith1200rs,
But will it change for offsetted sinewave? This is because, when we consider a square wave it is 0 to 5V. In the diagrams and explanation of slew rate, as shown in https://www.amplifier.cd/Tutorial/Slew_Rate/SlewRate.htm of the square wave , they have not shown negative cycle of square wave. So, i substituted my sinewave(since its offsetted/unidirectional) for that square wave and then found that slew rate should be theoretically 2*pi*fmax*Vp-poutput
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
I cannot see why offset should make any difference until you are near the limits of the output voltage where the slew rate reduces.
While simulations are not a perfect, a quick simulation with the OP37 confirms that.
Keith.
