Shepster
Newbie level 1
Greetings all, this is my first post here. Any help will be greatly appreciated!!
I have two LR8N3 High voltage regulators, A and B, both variable Vout.
Once a voltage has been set for each of them, I would like B to follow any further adjustment of A and maintain the voltage difference as set initially.
Example: A is set at 250 Vout while B is set at 200 Vout (initial setting)
(separate outputs)
If A is adjusted to 300 Vout, B follows to 250 Vout.
Is this possible? I think it might be fairly simple, but the details escape me!
Schematic shows circuit for A, B is identical.
thanks for your help!
(separate outputs)
